A backup hangs or stalls.
Causes
Right-click on our application icon in the bottom right of the screen. The name will be Server or Desktop.
You will see this menu, which allows you to stop a running backup.
After stopping the backup, click Exit
It might have stalled if the backup hadn’t stopped within 5 minutes.
If a backup is stuck on a running process, it usually contains a file named running that should be deleted from either location.
File location:
Windows server version
C:\Users\username\ .obm\ipc\BackupSet\ {BackupSetID}
Windows desktop version
C:\Users\username\ .acb\ipc\BackupSet\ {BackupSetID}
MAC
${User_Profile}.obm\ipc\BackupSet\Backupset_id
Delete the file named running.
Create a file named stop (no filename extension is required).
After a few minutes, the backup should stop.
